Route10 MAC Addresses
Purpose
Some ISPs will require you to register your router's MAC address with them (yes, even today). The Route10 has 2 WAN interfaces by default and can have up to 5 after configuration. This tool allows you to see the MAC addresses of every single interface on the Route10 so you can provide that MAC to your ISP regardless of which interface you're going to be using.
The MAC to input below is the 12 character string beginning with BCB9 in the middle of the Route10 Serial Number.
1 out of 2 found this helpful
