Add a Static Route
A Static Route defines a fixed path that network traffic should take to reach a specific subnet. Unlike dynamic routing, which adjusts paths automatically, static routes are manually configured and remain in place until changed or removed.
When creating a static route, you will always see the following fields:
  1. Name – An arbitrary label to quickly identify the purpose of this route.
  2. Type – The route type. Options: Next Hop, Interface, or Black Hole.
  3. Network – The destination subnet (not only a single IP, use /32 for single IPv4 address routes) in CIDR notation (e.g. 192.168.50.0/24).
  4. Metric – A numerical value that determines the route’s priority. Lower values are preferred over higher ones.
Depending on the Type selected, additional fields may appear:
  • Next Hop – Requires the IP address of the next hop router.
  • Interface – Requires the Interface to send traffic through.
  • Black Hole – No additional fields; traffic to the specified subnet is silently discarded.
Route Types Explained
Next Hop
A Next Hop route sends traffic for a specific subnet to another router for further delivery.
When to use:
  • Connecting to a remote branch office through a dedicated router, such as a provider-managed router on managed private WAN service.
  • Routing to a network segment managed by a different router in the topology.
Example:
  • Network: 10.5.0.0/16
  • Next Hop: 192.168.1.2 (router at branch office)
Interface
An Interface route sends traffic for a subnet directly out of a specified network interface.
  • When to use:
    • Routing across point-to-point interfaces such as VPNs.
    • Not to be used with Ethernet networks, as Ethernet requires a next hop for routing.
  • Example:
    • Network: 172.20.10.0/24
    • Interface: wg (Wireguard VPN)
Black Hole
A Black Hole route discards all traffic destined for the specified subnet without notifying the sender.
  • When to use:
    • Prevent routing loops.
    • Block traffic to specific IP ranges for security or policy reasons.
  • Example:
    • Network: 203.0.113.0/24 (unwanted external network)
    • Networks: 10.0.0.0/8, 172.16.0.0/12, and 192.168.0.0/16 to prevent routing RFC 1918 networks to the internet. The directly-connected private networks will have more specific routes (usually /24) which win over the less-specific routes, hence this does not break private network connectivity unless you’re using the full 10.0.0.0/8, 172.16.0.0/12, or 192.168.0.0/16 as the assignment on one of your VLANs.
Understanding Metrics
The Metric field controls route preference — lower numbers are chosen over higher ones when multiple routes match a destination.
Default metrics vary depending on the type of route:
Route Type Default Metric (Typical)
Connected 0
Static 1
Dynamic (OSPF, BGP, RIP, etc.) Variable (protocol-dependent)
For example, if you have a connected route to 192.168.1.0/24 (metric 0) and a static route to the same network with metric 1, the connected route will always be preferred.
For example, if you have redundant private WAN service with two provider-managed routers, you would add a static route with a lower metric pointing to the primary router, and a second static route with a higher metric pointing to the secondary router.
1 out of 1 found this helpful
