Dynamic DNS
Make Sure You Are Receiving a Public IP Address
With any VPN technology, it is important to ensure that you are getting a publicly accessible address from your ISP. Before proceeding with configuring your VPN, please ensure that you are obtaining a public IP address from your ISP.
What is Dynamic DNS?
Dynamic DNS (DDNS) is a method for ensuring that a memorable hostname always resolves to your WAN IP address. This is important for many home connections that host their own services such as a VPN endpoint with our Route10. The IP address to that connection may change periodically for a number of reasons, such as a power outage or ISP maintenance. With DDNS, that new address can be assigned to the name you registered every time it updates.
Enabling DDNS
By default, the Route10 sets up an automatically managed DDNS record in order to make the VPN and other tools as easy to use as possible. You can find this in the tooltip triggered by hovering your cursor over the IP address for your router as shown in the screenshot below.
Third-party DDNS
To use a custom DDNS provider, edit the WAN interface to find the Dynamic DNS client configuration.
Choose a provider from the list to get started. Your provider should provide some documentation to determine the correct values for the following settings.
In this example your DDNS hostname is myddns.example.com.
  • Hostname may be the fully qualified domain name (myddns.example.com), or just the base domain (example.com), depending on your provider.
  • Username may be the same as you use to login with your provider, or it could be the unqualified hostname (myddns). Your provider may clarify.
  • Password is defined with your provider. It may require you to generate a password, or they may provide a special token.
  • Public WAN IP discovers your public address by utilizing an internet-based check. This is useful to ensure that the updated DNS records point to your public IP in case your router WAN is on a private or CGNAT address.
  • IPv6 may be enabled to register an AAAA record with your IPv6 address. Otherwise, an A record is registered for IPv4.
Status of providers
Below is a table of providers enabled by the Route10 and the results of our testing. Comment below if you have an experience to share with us.
Service Username Password
Afraid.org (FreeDNS) none authentication token
All-inkl.com username password
AWS Route53
ChangeiP username password
CloudFlare1 Bearer API Key
Cnkuai.cn username password
Core Networks.de username password
DDNSS.de username password
deSEC username token
DHIS username password
Digital Ocean hostname token
DNSEver username password
DNSExit ? ?
dnsHome.de ? ?
DNS Made Easy username password
DNS-O-Matic username password
dnspod.cn secretId secretKey
Domain Offensive (do.de) username password
Duck DNS none token
DUIADNS.net none token
dy.fi username password
Dynamic DO.jp (ddo.jp) none token
dynDNS.it username password
Dynu username password
dynv6 none token
easyDNS username password
FreeDNS::42 username password
gandi.net non-qualified hostname bearer token
GoDaddy key secret
GoIP.de random random
Google Compute Cloud ? ?
hosting.de username password
Hurricane Electric DDNS hostname Password set for DDNS hostname
infomaniak username password
INWX username password
ipnodns.ru ? ?
IPv64.net none key
Joker.com username password
Loopia username password
Luadns Email API Key
moniker none key
MyOnlinePortal.net (MyOP) username password
mythic beasts username password
Namecheap Host DDNS password
njalla none key
no-ip.com DDNS key user DDNS key password
no-ip.pl (DNS Serwis) broken broken
Now-DNS.com ? ?
ns1.com (IBM) ? ?
nsupdate.info ? ?
one.com username password
OpenDNS username password
oray.com username password
OVH Cloud username password
pdns username password
porkbun username password
regfish none token
schokokeks.org username password
selfHOST.de username password
Servercow username password
Simply.com username password
Sitelutions username password
spDYN username password
Strato username password
trans ip username private key
UD Media username password
variomedia username password
YDNS username password
ZoneEdit username password
Provider Notes
1 CloudFlare requires the Domain to be specified as host@domain rather than host.domain.
Example: for ddns.example.com, configure the Domain as ddns@example.com.
3 out of 4 found this helpful
