Setting Up Alta Control With LXD
Alta Engineering
Alta Engineering
ALTA LABS CONTROL™ INSTALLATION GUIDE
Get a Free License
If you don’t already have a license, you can get one for free at: https://manage.alta.inc/control
• Minimum Firmware:
Please ensure that your APs are updated to firmware 2.0g or higher,
and switches are updated to 2.1c or higher. If you would like to update them without
requiring setup into manage.alta.inc, simply hold down the reset button for five seconds
while powering on the device, then release, and wait 1 minute for APs, and 3 minutes for
switches. Ensure that the device has an ethernet connection with Internet access prior to
this.
• Keep in mind that there are many variations of how an LXD/Docker image and network
can be deployed, and that these instructions will not cover all use cases. Comments
in purple indicate running commands from a shell. Anything highlighted in purple
bold will likely be different in your setup.
• Two architectures are supported: amd64 (i.e. x86) and arm64. Replace amd64 with arm64
below if you are running the controller on an arm64 host.
• Minimum System requirements: 2 GHz processor with 2 GB RAM and 8 GB storage.
      1. Download and install the controller of your choice:
          a. LXD image: https://dl.alta.inc/do-not-distribute/access/alta-control-amd64-1.2h.tar.gz
          b. Bridge your wired ethernet interface into a new bridge named br0: ip link show eth0
      2. eth0 may be enp2s0 or enp3s0, etc.
      3. Grab the MAC address after link/ether, to use in the next step
          a. Edit /etc/netplan/01-network-manager-all.yaml (replace 00:11:22:33:44:55
              with the MAC address from the previous step):
network:
  version: 2
  renderer: NetworkManager
  ethernets:
    eth0:
      match:
        macaddress: 00:11:22:33:44:55
  bridges:
    br0:
      dhcp4: true
      interfaces:
        - eth0
      parameters:
      forward-delay: 0
      stp: false
         b. Apply the configuration (sudo netplan apply), or reboot.
4. Create your lxc bridge network: lxc network create br0 parent=br0
5. Import and start the container:
lxc image import alta-control-amd64-1.2h.tar.gz --alias control
lxc launch control -n br0 control
lxc exec control bash
ip a (to get the IP address)
6. Using macvlan instead of bridging to a host bridge interface is also supported,in case you are unable to bridge to a host interface (to be run after creating the “control” container):
lxc config device add control eth0 nic nictype=macvlan parent=<host-interface> name=eth0
Notes:
If you don’t bridge/macvlan the container to your LAN, it will not automatically detect and
set up APs. You will need to go to the web server of the unconfigured AP, and set the URL
to match your controller’s hostname (including https://).
If you’d like to import the image into Hyper-V, ESXI, or any other virtualization host, the raw
root filesystems can also be found at:
https://dl.alta.inc/dev/control-amd64-1.2h.tar.gz
https://dl.alta.inc/dev/control-arm64-1.2h.tar.gz
