LED Patterns for Access Points
Normal Boot
  1. Blue LED turns solid for a few seconds
  2. Blue LED blinks for approximately 20 seconds
  3. White LED turns solid
Factory Reset
  1. After device has booted, user holds reset button down for more than 5 seconds
  2. LED blinks white, and resets its configuration
  3. After configuration is reset, device will boot normally, and be ready for Set Up into a controller
I Followed The Power-On-Reset Steps but my AP LED is blinking blue
This indicates the steps were not successful. The most common reasons are:
  1. No ethernet link
  2. Failure to acquire DHCP lease
  3. Failure to reach Internet
  4. Failure to obtain time sync
  5. Failure to download firmware from server
If you believe none of these issues apply, please contact our support team for further assistance.
Automatic Firmware Recovery (Power-On-Reset or “POR”)
Generally, a POR won’t be necessary unless instructed by our support team.
Please see this article for the process of recovering firmware.
1 out of 1 found this helpful
