How To Enable Multi-Factor Authentication
Enabling Multi-factor Authentication
  • Step 1: Log In
  • Step 2: My Account
  • Step 3: Enable MFA
Step 1: Log in
Step 2: My Account
  • In the upper right hand corner, click on the circle and select "My Account".
Step 3: Enable Multi-factor Authorization
  • Under "Security", select either "Enabled App-based Multi-factor Authorization" or "Enable SMS-based Multi-factor Authentication". Now follow the instructions to set up MFA.
If you have difficulties enabling MFA, please contact Tech Support.
